Warrick 1G2D0 Discontinued
Hi,
I have a pressure pump controller that seems to be failing. It's different from what I could read on this forum as there is no obvious capacitor.
The model of the controllers are Warrick 1G2D1 and 1G2D0. Only 3 wires go to the pump, including the green one (black, white, green).
Looking on the web for replacement parts, I found out that it is discontinued.
Do you guy know what I can use to replace them? Or should I replace the whole thing, controllers and pump?
Thanks,
Talaron
Thanks,
Talaron
Welcome to the forums.
Warrick 1G2D1 and 1G2DO appear to be relays and are still available. I don't know how they are connected so I can't offer any help on replacing that particular control box for another. If there is no capacitor then there must be a timing module for start up.
Someone else may be familiar with the system. If not, you may need to replace the pump and controller as a set.
