Septic tank cover removal
Old 10-11-14, 01:17 PM
daswede's Avatar
I'm about to have my 1000gal. septic tank pumped out.
In struggling to lift the square 2ft. x2 ft. square service(heavy)cover I noticed the
lifting rod imbedded handle, distorting badly.
Afraid of pulling any more on it, I carefully cleaned out the joint between the tank, and cover
and used a couple of pry bars to carefully raise the tank top high enough to grip with my hands.
I assume there is a better way to do this, and a better way to prevent the tank cover from getting so wedged in top opening again.
I'd appreciate any advice on this.
Thanks.
Old 10-11-14, 02:23 PM
V
Received 2 Upvotes on 2 Posts
I just removed one of those covers a few weeks ago. It was about 24" below grade and I used a chain to hook onto the embedded rebar handle and then a rigid 8' steel pike to serve as a lever and a 6"X6" block of wood to serve as a fulcrum. Once detached, you can manipulate it . . . . but it's still a mite heavy from 2' above.
I've noticed that most of the septic tank pumpers prefer to pump from the inlet or outlet ports, (which are a lot lighter).
Old 10-11-14, 02:50 PM
daswede's Avatar
Thanks for your reply. Those things are a bugger.
When the Septic tank company comes, or sooner, I'll probably purchase a new lid, as mine is starting to crumble.
Winters in the Northeast here are no time of the year to have to deal with septic systems.
Old 10-11-14, 02:58 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
How deep is it? IMO install a riser...
I use products from here normally.
Segmented Risers
Old 10-12-14, 06:32 AM
daswede's Avatar
Thanks for your reply. I'll run that by my Septic tank service tech when he comes next week.
Old 10-12-14, 07:37 AM
Received 1 Upvote on 1 Post
your pumper should be doing this as part of his work
