Accumulator tank
Accumulator tank
i'm using a Flojet pump with instructions to NOT use with an accumulator tank. Is this the same as a pressure tank?
You did not say specifically what pump you have. Flowjet makes many different models and some even come with a pressure tank attached. Most of their models though are demand type where the pump simply turns on and off as needed to regulate the water pressure.
