Water tank question
Old 03-23-15, 07:48 PM
T
Water tank question
Can someone identify what these tanks might be. I assume they are for water softening. I don't have much more information. Can't upload photos I guess they're too big. Anyway there are 2 tanks, rather large with WellMate on the name plate. Each seem to have 120 gal capacity
ETA: I just Googled these tanks. Seems to be a water storage tank. There is also a pressure tank not sure of the capacity. I'm thinking this might be a sign that water isn't plentiful in the area. Anyone have any insite
Old 03-24-15, 03:27 AM
T
Just a little more information Not that I have that much experience but its a strange set up. There are 2 of these tanks that are labeled with 120 gal capacity.They have water system pressure tanks on the label. They are piped in series and there is also a regular blue colored Amtrol pressure tank ( Wellxtrol model )
Sorry I can't post pics. The ones I took with my phone are too big.
Old 03-24-15, 03:45 AM
Received 742 Upvotes on 648 Posts
this might help - http://www.doityourself.com/forum/el...your-post.html
you could also post the pics to a site like photobucket and then provide a link to the pics. I know pics can be resized but I'm not smart enough to know how
Old 03-24-15, 06:28 AM
P
Received 1,776 Upvotes on 1,588 Posts
I think every photo program or app includes the feature to resize a photo. In Windows Paint right there in the home tab is a button to "resize". Most photo gallery apps for smart phones have a resize feature though different apps put it in different areas. Sometimes it's hidden under "export" and sometimes it's in the photo editing section.
Old 03-24-15, 03:25 PM
T
OK I resized the photos
Here are the water tanks in question. I also originally posted this in the water softener forum. I thought at first it was some sort of softening system now I think its some sort of holding tank for water
Old 03-24-15, 03:51 PM
A
Received 251 Upvotes on 231 Posts
In the path from the well to the faucets, is the blue tank first or last?
Those two large tanks, connected in series, will not allevate a problem with low gallons per minute from the well.
If the well pump cannot keep up with the water being drawn, once the pump falls behind by about 15 gallons (about half the capacity of the blue tank half of which is filled with air to start with, all of the water will have exited the blue tank, system pressure will drop to near zero, and only a trickle equal to the pump delivery rate will continue despite the capacity of the big tanks.
Old 03-24-15, 03:53 PM
Received 3,424 Upvotes on 3,070 Posts
Looks like provisions for a lot of water storage.
However the fact that they are connected in series is baffling since the way they are connected you cannot put an air charge in to the two big tanks as they are drawing from the top of the tank. The ID plate you posted says water storage device otherwise I would think they were some type of processing or filtering units.
As it stands now.... if those tanks are indeed water storage only.... they aren't doing anything for your water supply system.
The blue tank is definitely a pressure type water tank and is first in line from the well.
Old 03-24-15, 04:20 PM
A
You could get a lot more water draw despite a low gallons per hour well or well pump. You would connect up the two big tanks as if they were pressure tanks, using just the bottom opening of each.
As pressure tanks the big tanks will accept water to about a third to a half their capacity depending on pump turn off and turn on pressures. But they will allow the system to actually deliver a lot more water compared with using them as storage tanks completely full of water.
The amount the pump can fall behind before you lose pressure would then be roughly 90 to 140 gallons depending on pump turn on and pump turn off pressures and precharge air pressure for each tank, namely about a third to a half of the capacity of each of the 3 tanks in most cases. You would actually get a little more water than that; the pump is contributing something in addition to what is in the tanks to start with.
Old 03-24-15, 05:02 PM
T
AllanJ, the blue tank is connected to the pipe coming in from the well.
I know at one time this house had a Culligan water softening system installed. Maybe those tanks where something to do with supplying them with water.
Old 03-24-15, 05:39 PM
A
If you convert those large tanks to pressure tanks it does not matter which comes first. The total system pressure will be roughly the same as it was before (The system pressure is not 3 times the pressure in one tank because you have 3 tanks.)
You will need to install some kind of valve in the top of each tank that you could pump air into for the purpose of setting the air cushion inside to a desired amount. It may require some conglomeration of pipe fittings to adapt a Shrader valve (the kind at the top of the blue tank or the kind of air valve for a tire).
Old 03-25-15, 05:26 AM
biermech's Avatar
Received 3 Upvotes on 3 Posts
This tanks are used for contact time. It looks like there is an injector for a chlorinator between the pressure tank & the first tank in line.
Old 03-25-15, 05:52 AM
T
Thanks biermech. Why would they want to inject chlorine? Bacteria in the water?
Old 03-25-15, 06:46 AM
T
I emailed Wellmate the serial # of the tanks last night to see if they could me about them . They returned my email this morning asking for pics. Low & Behold Gordon from Wellmate called me on the phone to discuss what he saw in the pictures. He did mention the same as you Biermech about the chlorine injection system. Seems information is slowly coming together on this water. Many thanks to those that replied and gave some information.
And kudos to Gordon at Wellmate for going above & beyond by taking the initiative of calling me ( without my request ) to discuss this water system.
Old 03-25-15, 02:36 PM
T
Follow up
I spoke to the local Culligan agent. They were the people that installed the water treatment system. This is the equipment that was installed and the reason they installed it: Stenner feeder using chlorine with a 9" hard shell tank (used for odor), Stenner feeder using alum (used for clay), and a 20" sediment filter. Does anyone know the cost of running such equipment? IT would be a household of 2 adults
Thanks Tim
