where to buy rubber grommet to seal PVC pipe
Old 05-01-15, 08:31 PM
Q
Hello all,
I am working on seal the sump pump cover. In order to completely seal all discharge pipes, I need to find some rubber grommet to tightly seal PVC discharge pipes.
Question> Do you guys know where I can buy those rubber grommet?
Thank you
Old 05-01-15, 08:38 PM
Rough Rooster's Avatar
Received 7 Votes on 7 Posts
Check this out. You may not like the price.
Grommets | MSCDirect.com
Couldn't check Grainger as they had website down for maintenance.
RR
Old 05-01-15, 09:03 PM
F
Received 36 Votes on 28 Posts
Best to do your own Internet search. You need to know the thickness of the cover plate, and the outside diameter of the PVC pipe will be the inside diameter of the grommet. Most suppliers will have a minimum quantity, often 50 or more units so Ebay is probably your best source.
Old 06-12-16, 06:17 AM
T
Rubber grommets for sealing pvc pipe
Hi, I had a job that required this about 2 weeks ago. I had some luck here https://www.rubberfeetwarehouse.com/...ubber-grommets. Good luck
