Air bubbles in stream after pump runs awhile
I am resurrecting an old well and I do not have any details on the well capacity. I currently have a manual switch and the pump discharges outside through 1" pipe. After running the pump for awhile (I have been clearing out sedimemt and iron/manganese deposits) a small stream of air bubbles is noticed, however the water volume does not decrease noticeably and there is no significant noise from the well. I am wondering if the drawdown comes close enough to the top of the pump that a vortex is forming causing the air. The casing is 4" and there is not much clearance between pump and casing. The water is pretty clear now, and I seem to be able to run indefinitely without loss of volume.
Is a vortex the likely cause, and if so do I need to be concerned? Or is there something else going on (that I need to be concerned about)?
Thanks.
Thanks.
The well bottom is about 95 feet below the basement floor, static water level has been about 15 feet below the floor. I set the pump down 80 feet. It is a 1/2 HP 230V 3-wire submersible pump, rated at 10 GPM at this depth. I have not done a precise measurment, but it seems to be delivering close to its rating. Drop pipe is a single length of polyethelene 1" pipe.
I suppose a vortex is possible especially since you've probably got a very high flow rate if the only thing connected is 1" pipe which you are letting run free. If you are getting a vortex I would assume though that you would pump the well dry and draw a huge amount of air soon after. With a 1" pipe and wire inside a 4" diameter casing I doubt a vortex could be very tall so if it's happening the water level is down pretty close to the pump.
Another possibility is if you have a hole in the pipe down in the hole. When the water level is high the hole is covered but when it's pumped down it could suck in air via a venturi action.
Thanks, Pilot Dane, I wondered about a leak but thought that was unlikely with a single continuous length of polyethelene pipe. I do not ever seem to pump the well dry, so it seems that the water level is at a stable point. If it is a vortex, I must have just been lucky to get the pump set at exactly the right/wrong depth. Having no information about the local water table or this well, I can't guess whether a 65 foot drawdown is reasonable.
To review, for the first half hour or more of pumping (full flow) there is no air.
I'll add that my intended use of the well is for watering the lawn/garden through standard garden hoses and sprinklers, so I may never see this air situation when connected to 3/4" plumbing, garden hoses, etc. Now that the well is pumping clear, I would only use this discharge path if it needed to be flushed again in the future.
