Easement for drain field
Old 10-15-15, 06:55 PM
ukrbyk's Avatar
Received 46 Upvotes on 37 Posts
Hey, septic people, from common sense and maybe real life experiences, how much of a hassle is it to have easement in your property for neighbor across the street septic system? It's quite common here.
Property is 6 acres. House is quite far away from that easement. 102 x 140 ft easement.
Just curious. No worries, will be PITA? What say you?
Old 10-16-15, 02:57 AM
V
Received 2 Upvotes on 2 Posts
As a Broker, I've dealt with setting these Easements up . . . . just make sure that the System is properly engineered and so that you (as the Serviant Land Owner never suffer from some disruption caused by a mal-function of the dominant party's disposal area.
An Attorney should draw it up for execution by both Parties and it should be recorded in your Land Records so that it can't be missed by any future Owner of either property.
It cannot help but diminish the value of your property; but a nominal rent or lease fee can adjust for that. If it's common there, you should be able to review comments by the suppliers of such Easements (Servient Owners) and the Users (Dominant Owners), and make sure the language of your Easement avoids the problems they have encountered.
Old 10-16-15, 04:23 AM
B
Received 47 Upvotes on 43 Posts
Six acres is nice, but I have always divided that by the minimum lot size to mentally judge whether an extra lot or to might be possible in the future. Locating an easement on that property could eliminate a future lot and potentially a lot of money. Just commenting.
Bud
Old 10-16-15, 06:51 AM
ukrbyk's Avatar
Thank you.
It's in 15% of the property assigned as wet land. Can't be built on anyway.
I have county legal doc for it but it does not provide any grantee name. It's a mystery title company and realtor are working on.
Neighbor property south of one discussed does have drain field from house across the street from it. I'm suspicious it's same case here.
I have no 1st hand experience with this though and curious how much possible headache it is reality of life wise.
Old 10-16-15, 06:58 AM
Received 742 Upvotes on 648 Posts
If it's classified as wet land will they even permit a drain field on it? Doesn't sound like it would work correctly during the raining season.
Old 10-16-15, 08:55 AM
A
Received 251 Upvotes on 231 Posts
Does the easement already exist?
Do you already own the property?
Is there street access directly to the easement area?
Old 10-16-15, 10:35 AM
B
Is this for new construction or has an existing system failed? If an existing system has failed, do they have an alternative, maybe an expensive one. IMO, new construction, it should not be allowed. A hardship case for an existing failed system should come at a price.
Bud
Old 10-17-15, 06:20 AM
V
Originally Posted by ukrbyk
". . . It's in 15% of the property assigned as wet land. Can't be built on anyway . . ."
If that's the case, then it doesn't sound like it would ever pass a percolation test for an engineered system either.
Around here, if it were designated a Class 2 Wetland, you can't do much with it at all EXCEPT pay taxes and look at it (with a Permit).
Old 10-17-15, 06:47 AM
ukrbyk's Avatar
Sure can. Duck pond.
So according to Norm the surveyor said easement is an error and now they are "working with county to have it corrected asap".
So it's all at halt till that happens.
