Mold in sump pit
Old 10-23-15, 09:16 PM
T
Mold in sump pit
My sump pit is plastic, but there is a hole cut in the bottom of it, and then a layer of gravel, and the pump itself sits on a paver stone so as not to suck the gravel up. However, there is a couple of inches of water that remains after the pump runs due to the pump being elevated. In this couple of inches of water, a grayish blob of mold has grown over the gravel.
How can I get rid of this mold? Someone had suggested I pour a little bleach in, but I'm not sure if that's ok since the pump drains to the yard.
As a side question, why would someone have cut a hole in the bottom? Is it to let any ground water from below the pump in? Is this normal or should I try to seal it?
Old 10-24-15, 12:57 AM
Received 1,481 Votes on 1,369 Posts
The little bit of bleach you'd use in there would be diluted by the time it reached the lawn.
Old 10-24-15, 10:50 AM
Received 1 Vote on 1 Post
if you don't put holes in the sump, it'll pop out of the hole,,, boats float, remember ?
get a stick & scoop that mess outta there ! bleach will kill the remaining spores but won't destroy or liquefy what's there
