Sewage ejector elevation
I have a system in which the grey water is pumped out of the septic tank and out onto the ground via a sewage ejector, the kind that has a 1" line inside a 4" pipe in order to allow for the water in the 1" line to settle down low (well below the frost line, 8' or so) in the 4" line when the pump shuts off. this prevents the 1" line from freezing.
My situation is this;
When my pump shuts off, the 4" pipe slowly fills to within 1' of the top, causing it to freeze. I highly suspect the this is because my ejector is at a lower elevation then my septic tank. Am I right in thinking this ? If so, what is the fix ? I was thinking a check valve to stop the flow towards the ejector, but that is the direction the water must flow to be pumped out. Is there a special kind of check valve that requires certain pressure (the pump running) to open, otherwise (siphon action from the ejector) it stays closed. Am I on the right track with my thinking ?
Many thanks,
Myles
Many thanks,
Myles
I answered my own question. Yes, if your ejector is at a lower elevation than your septic tank, you need what is called an anti siphon valve which is NOT the same as a check valve. This valve is installed on your pump on the discharge line.
....for those of you who may be wondering.
