how to check if old well is properly sealed/closed off
Old 03-24-16, 12:12 PM
Q
Received 1 Upvote on 1 Post
We have an old artesian well on the land, which has been disused for 30 years.
It has a smaller diameter white PVC pipe stuck in it on the inside of the metal but not sure why.
I want to check if it is properly blocked off as the newer well is around 100ft away so don't want it to ever get contaminated.
Old 03-24-16, 12:49 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
If it has PVC inside the metal, it was sleeved to cut down on rust contamination. Sometimes it works, sometimes it doesn't. If you look at the top of the pipes and there is no cover, they aren't covered. Not sure what you are asking, really. The new well can be drawing from the same stratum, so you never know. How deep was the older well? How deep is the new one?
Old 03-24-16, 02:00 PM
L
the well had been properly seal both casings would have first been filled with sand to the top of the water table. Next a minimum of 3' of Bentonite pellets would have been placed on top of the sand. Lastly both casings would have been filled with Bentonite grout to the top of the casings. This is how we seal wells that were surrounding our landfill.
Old 04-24-16, 03:31 PM
Q
It's not really properly PVC sleeved, just looks like someone inserted a pipe but can't see any reason for it:
Old 04-24-16, 04:31 PM
Received 125 Upvotes on 110 Posts
No way is that old well going to have any effect on the new well.
Old 04-24-16, 05:24 PM
Q
Why not? It's about 50metres away. Could be tapped into a different layer I suppose.
Old 04-25-16, 02:43 AM
Received 740 Upvotes on 646 Posts
What diameter is the PVC pipe? Wells that have the pump above ground will have a PVC drop pipe [usually 3/4"] Can you pull up on the PVC? I'd want to at least put a cap on the casing.
Old 04-25-16, 05:52 PM
Q
3" PVC pipe, the well is 6 inches
Tried pulling the white PVC pipe out but it doesn't budge.
Could cover it but guess that doesn't stop bacteria or other critters from developing.
Old 04-29-16, 04:40 AM
Q
So, pour bleach down it and then add a cap? Does it need to be filled? Is it in fact still useable?
Old 04-29-16, 04:43 AM
If there is enough water the well would likely be usable. Whether or not it's safe for human consumption and not just irrigation would be determined by testing the water.
Old 04-30-16, 07:33 PM
Q
It's not used so what I'm worried about is contamination of the other deep well within 100ft.
Just wondering how to block it up myself.
Old 05-01-16, 03:34 AM
As long as it's capped it's unlikely to get contaminated or affect the other well.
Old 05-01-16, 04:19 AM
Q
The other well was capped for years but it was tested 2 years ago and had minor amounts of coliform. We disinfected and everything has been fine since but the lab tester said it normally happens when water is left stagnant for long periods. So, could happen even with a cap.
On second thoughts, how can I remove the white plastic 3" pipe to check if there is a pump down there still? The pipe doesn't move easily.
Old 05-10-16, 04:48 PM
Q
http://www1.agric.gov.ab.ca/$department/deptdocs.nsf/ba3468a2a8681f69872569d60073fde1/c3e2c0f3d3a0baf887256a5a00668ba8/Information/0.8280!OpenElement&FieldElemFormat=gif
Old 05-15-16, 08:00 AM
L
Can you get a pair of Vice Grips on the PVC pipe to see if you can pull it out? With water showing at the top of the PVC means there is a pump or a check valve at the bottom of the pipe. If you can move the PVC, get some one to help you pull the pipe. Use a 18" to 24" pipe wrench around the PVC as a hold fast when you pull the pipe. Pull the pipe up about 2' then hold the pipe with the pipe wrench to keep it from sliding back into the steel casing. After pulling out the 2', you will be able to grasp the pipe with you hands and continue to pull out the PVC and hold on with the pipe wrench.
