Can this charger take "Wayne WSB1275 75Ah AGM Sealed Lead Acid Battery"?
Hello all,
Can my charger take Wayne WSB1275 75Ah AGM Sealed Lead Acid Battery?
Which setting I should use for the Acid Battery?
1> Calcium
2> AGM & WET
3> GEL
Thank you
1> Calcium
2> AGM & WET
3> GEL
Thank you
1> Calcium
2> AGM & WET
3> GEL
Hmmmmm..... I'd pick setting number 2.
Just as a side note..... if you are using this battery on a battery backup sump pump system..... you can't use two chargers at the same time. The backup system has an internal charger.
1> Calcium
2> AGM & WET
3> GEL
What do you mean two chargers?
My understand is that the WSB1275 just a battery without any charger.
Please correct me if I am wrong here.
thank you
thank you
Are you using the battery you referenced on a battery backup sump pump system ?
If yes...... the backup pump system already has a charger built in to it. You can't just connect a second charger on to that battery.
I just want to buy a sump pump battery to replace my old one and still plan to use the old charger.
It ought to work. The charger has a setting for AGM batteries, and AGM batteries can be charged at 0.2C = 0.2 x 75Ah = 15A. Charging at the max 16A would likely be fine. Restrict it to 8A if you have concerns.
