Mount pressure switch up high
Just a quick question, I'm planning to replace the pressure switch on my
deep well, (5hp, a little over 400') . Is there any reason it needs to be at the base of the pressure tank? I have a maze of pipes in and out of the 2 pressure tanks to accommodate the sand filter and whole house filters, and frankly at my age crawling around on the floor has lost its novelty. I plan to mount it on the intake of the sand filter, as that is chest high, yet still on the pump side of everything.
Where you mount it specifically is not important as long as you install it before your filters. I like to mount them so there is a vertical pipe nipple connecting it to the water system. A long nipple is preferred. This helps prevent sediment in the water from reaching the pressure switch though sometimes the pipe nipple can clog or rust shut.
Thank you for the prompt reply, that resembles what I'm plumbing. there will be another T below it as I'm also including an eye level gauge. For now I will just abandon the old switch, shouldn't hurt anything, maybe in the summer, I'll clean things up. For now getting it running is top priority.
Reporting back; What I first tried did not work, as the switch would pulse several times both on cut in and cut out. That was no doubt bad for the controller and pump. I moved it to the other side of the pressure tank just before the filters. While the arm in the switch rocked back and forth a bit at both ends of the range, it no longer pulsed the relay in the controller. I'm thinking at this point that; on an outlying point, out of the stream would be best. I never imagined how turbulent the main pipes are. lesson learned. Let's hope if I can't be an inspiration, I can at least be a lesson.
Received 93 Upvotes
Eric-
If I understand correctly, that sounds like contact chatter in the pressure switch. I think that can happen if your pressure switch is too far from the tank. I think the recommendation is that the switch should be no more than 6 feet from the tank (I’ll see if I can find references to that). Although in my old setup my switch was about 8 feet upstream from the tank with two 90 degree turns between the switch and tank- and that worked OK.
Well here's one from I guess pros, but I've heard 6 feet most of the time. They say 3-4 feet.
Reasons for Pressure Switch Chatter - Lakeland Water Pump Co.
…While the arm in the switch rocked back and forth a bit at both ends of the range,…
I'm contented for now, it cuts on and off smoothly, I got my original wish, it is now chest high and easy to service, I put in a new switch so it should be good for a while. I probably will put a longer 1/4" pipe nipple, the one I used was 1 1/2" long, double that should make a bit of a shock absorber.
