Water pressure problem
I just had my well pump replaced earlier today, at first the pressure was fine but after some time my water pressure has weakened a lot. At first when I turn the water on it's fine then slows down. Any idea what it could be? Could I have had a bad pressure switch too and that be the problem?
Welcome to the forums! You must have, in combination, a good non leaking pump, a pressure tank and piping that doesn't leak. One of these will cause pressure problems. Since you just had it installed, call the installer and have him do it right and get you the pressure you need.
