Can a pressure switch be installed 200 ft away from a pressure tank/well?
Old 05-09-17, 05:42 PM
Hello,
I have my well about 200 ft away from my house and I need to walk there each time, if well pump stops due to various reasons. One of them is clogged sediment filter. I managed to control remotely the sediment filter cleaning, but can't do that with pump start. Pump stops if it's clogged, as you probably know.
I couldn't find how to start it remotely and I couldn't find any electronically controlled pressure switch(pump is submersible). If you know something about restarting it remotely, please let me know.
So, I am thinking installing it inside of the house. Will this work, if it's that far from pressure tank and well?
Old 05-09-17, 06:44 PM
Received 3,415 Upvotes on 3,063 Posts
Usually when the pump stops running you make a visual check of the pump house to look for problems. So even with a remote control you don't have a clear understanding of the problem.
When your pump stops running due to a clogged sediment filter..... what happens ?
Breaker trips at pump house?
What actually does the shutting off.
Old 05-09-17, 08:12 PM
I need to start it only for situation when filter is clogged. Using remote control I clean the filter and want to start it again. In case, if it won't start after the cleaning, then I would go and see what is wrong.
Old 05-09-17, 08:26 PM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
You didn't explain/answer the question. What stops it when the filter clogs? Does it just overload? Do you need to push a reset button at the pump to start it?
How the heck do you remotely control cleaning a sediment filter?
Old 05-10-17, 03:08 AM
V
Received 2 Upvotes on 2 Posts
Where is the Sediment Filter now located ?
Old 05-10-17, 03:44 PM
Pressure switch stops it. If it occurs, I clean the filter and then I need to go there to lift a small lever and hold it under 45 degrees to start it back.
I've bought a remote control and normally closed solenoid valve.
Old 05-10-17, 03:47 PM
It's located by the pump, before the pressure tank.
Old 05-10-17, 03:56 PM
That lever on the side of the pressure switch is a low pressure safety. It's job is to shut the pump off if there is no pressure. In order to reset it.... you need to hold that handle until enough pressure builds to take over.
So your sediment filter is before the pressure tank and the pressure switch.
I don't think I'd consider moving the pressure switch to the house.
