Complete well system
Old 06-20-17, 08:18 AM
T
Can anyone explain to me how this system works? (if it does) Seems to me there should be a separate line in and out of the tank?Name:  DSC01232 - Copy - Copy.jpg
Old 06-20-17, 09:25 AM
Tank normally has one connection. Tank has pressurized air behind a diaphragm. Water is pumped into the tank until the pressure turns off the switch located in the brown box by the tank connection.
This setup makes a certain amount of pressurized water available before the pump must run again. I can't see your piping arrangement clearly enough to comment. Steve
Old 06-20-17, 12:48 PM
P
Received 744 Votes on 684 Posts
Does your well also supply another house or building? Do you have an irrigation system? I'm wondering why you have two large supply lines heading outside.
Old 06-20-17, 04:43 PM
Received 1,317 Votes on 1,217 Posts
The tank has air in the top and water in the bottom. Usually separated by a rubber membrane. As the water pressure goes up.... more water comes in the bottom of the tank, rises and compresses the air cushion.
A simple one line connection to it is all that's needed.
Old 06-20-17, 08:45 PM
T
Pilot Dane, There is only one going outside. I think it goes to an old building, I will cap it off. Thanks for the replies.
