Size compressor to blowout irrigation pipes
My irrigation system runs off a pressure tank at 30-50 psi with polypropylene pipe.
The longest run is about 200ft and it supplies around 10GPM.
What size compressor should I get to blow it out? 10cfm or less should be fine but how many gallons is required at a minimum?
I use my shop 60 gallon compressor and it does a great job, I've seen folks do it with a 30 gallon but it takes some time.
Anything smaller and your going to run out of air before you can get the water out.
How you connect will depend on your system. When planning my system I added a Tee fitting with a 3/4" threaded female adapter. Then I bought a brass 3/4" cap, drilled and taped a hole, and installed a air hose fitting like you would install on an air tool. That connects directly to my air hose.
What did you have to drill a hole in? Isn't there a fitting that can go straight onto the water system?
I have some 3/4 barb tees with a 3/4 male thread...
Ok, the part I'm confused on is the cap.
A 3/4 cap is a threaded cap that you drill a hole in.
But there's no threads on the other side, so how do you connect the air compressor to the cap?
Secondly, assume air pressure works similar to the pressure built up in the water system. If you drill a small hole in the cap, aren't you reducing the amount of air that can flow through the system to the size of the small hole?
You missed the part in my post #5 that said I taped the hole to fit the air line fitting.
Buy one of these: Everbilt Lead-Free Brass Pipe Cap 3/4 in. FIP-801989 - The Home Depot
Buy one of these: Husky 1/4 in. MNPT x 1/4 in. I/M Steel Plug-12224HOM - The Home Depot
Drill and tap a hole to fit the air fitting. The 1/4" hole is more then enough for air to flow and push out the water. Just think how fast the air comes out an air hose when you disconnect it from a compressor.
You could also try to find a 3/4" to 3/4" coupling and then reduce it down to the air fitting, but IIRC it was cheaper for me just to drill a hole and tap it.
Received 38 Upvotes
Rather than having to drill and tap a cap why not use a 1/4 by 3/4 inch bell reducer?
Or, better still, connect a garden hose connector to the largest port on the air tank (use a ball valve in between) and then a short length of garden hose to the sprinkler system. It is VOLUME, not pressure, that you need to blow out the water.
garden hose is usually 1/2" connectors?
If so, could I just put a faucet onto the 3/4 polypipe and then connect the air compressor to the faucet and open it?
The part I am confused on is how to get the air connector into a plumbing thread?
The suggestion was to drill a hole in a plumbing cap I think, but then I'm not sure how you would attach an air compressor to that, they're all different sizes.
Not sure if I am understanding your question or not, but taking a stab at it. Are you asking how to connect the coupler on the end of the air compressor hose to NPT? You can either remove the coupler from the end of your air hose, leaving you with a standard NPT to connect with, or you can buy a nipple at your local auto parts store, hardware, or big box, which you can thread into your system and then connect your air hose to.
I thought water NPT and air NPT were different sizes? ie you can't get compatible?
If you can then why drill holes in caps, etc. Why not just get a 1/2" threaded nipple connect to a 1/2" female on the water pipe and a 1/2" female on the air hose?
"I thought water NPT and air NPT were different sizes? ie you can't get compatible?"
There are of course different thicknesses of pipe and fittings, with varying pressure ratings, depending on the application, but NPT threads are NPT threads, whether used in water or air or whatever. So, for what you are doing qwerty, it's simply a matter of having the right fitting(s) to adapt your air compressor hose to your water line. The only hiccup would be, and this may be where you thought there was a difference, is that garden hoses and spigots use a unique 3/4" garden hose thread.
