Changed sump pumps and question regarding pipe connection
Old 02-17-18, 10:14 AM
Question Changed sump pumps and question regarding pipe connection
Hi there,
So our old sump pump stopped working and we purchased a new one. The piping is 2 inch but the old pump had a 1 1/4 outlet so the existing piping has a 1 1/4 check valve. Now the new pump has a 1 1/2 outlet and so the check valve is too small to screw in.
So, i know we can just redo the piping and get a 1 1/2 check valve but is there another way experts would do it or can i Macgyver it?
I did find adapter for both ends but could only find ones where i still would need some kind of 1/ 1/4 to 1 1/2 coupling or something. (see pics)
Thanks
Old 02-17-18, 10:53 AM
Received 1,532 Votes on 1,415 Posts
Welcome to the forums.
Your new pump has an 1-1/2" outlet or discharge port.
A 1-1/2" check valve would allow for maximum water flow.
You could use a 1-1/2" pvc male thread to 1-1/4" female thread adapter at the pump.
Old 02-17-18, 11:12 AM
Attachment 90663
Thanks, Outlet is what i meant. Thats exactly what i thought i would be able to find but I checked the hardware stores here and didn't see something like that but i'll check again. I'm in Canada so i checked Home Depot and Lowes. Thanks
Old 02-17-18, 11:35 AM
I can't find them using the depot online search but I'm pretty sure I've seen them at my little store. A larger store should have them.
pvc fittings online-schedule-40-pvc-reducer-bushing-flush-style.html
Old 02-22-18, 08:26 AM
Just wanted to update as i never was able to find that adapter but managed to get the old check valve off and installed a new 1 1/2 check valve and pump is up and running just in time for all the rain and snow melt Thanks everyone
