2" Jet Pump - Worth putting a pump on casing?
Old 05-05-18, 11:33 AM
C
I've purchased a piece of property with a 2" jet pump casing. I'm hoping to put a shop on the property and would like to have a bathroom and water for occasional irrigation. Is it worth putting a pump on the casing? I'm getting mixed opinions if it is worth even trying to hook a pump up to it.
Old 05-05-18, 12:42 PM
Received 3,419 Upvotes on 3,065 Posts
Firstly you would need to know how far down the water is.
A one pipe jet pump can only lift from a maximum of around 25'.
Old 05-05-18, 12:59 PM
C
How can you tell the depth of the water when there's a packer? I can fill the casing with water and it will hold for a little while so I think the packer is good. The property had a house on it for many decades but it was finally removed due to its poor condition (to my knowledge not a problem with the water).
Old 05-05-18, 01:29 PM
Received 740 Upvotes on 646 Posts
I haven't had a well in over 25 yrs so things may have changed but I had a 2" well in fla that was a little over 100' deep, pumping at 80' that utilized a jet pump with a single drop pipe. It worked well for the dozen yrs I lived there.
Old 05-06-18, 08:15 AM
C
Marksr: Do you recall what pump you had on it?
Old 05-06-18, 09:35 AM
That was too long ago and my memory isn't what it once was. It was a name brand pump, had to repair it once and I think maybe it had a 1hp motor.
