Well chlorinator
Old 07-21-18, 04:45 PM
K
Well chlorinator
At wits end. I have a Chemtek pump. Checked pump and the inflow and outflow lines are in right direction. Have a Stenner chlorine injector. Replaced the whole injector and new duckbill. Water from the well is still back flowing into the chlorine reserve tank. I’m baffled.
i have unscrew the line from the injector and the duckbill isn’t allowing water to back flow. Something has to be pulling water through
Old 07-21-18, 09:16 PM
GregH's Avatar
Super Moderator
Received 66 Upvotes on 61 Posts
Thumbs up Welcome to our forums!
There needs to be a check valve on the chlorine line right where the chlorine line enters the water line.
Old 07-21-18, 11:36 PM
Marq1's Avatar
Received 1,103 Upvotes on 1,003 Posts
The duckbill is the check valve.
The duckbill has to be bad, even if the pump was backwards if the seal was good it could not pull liquid.
Old 07-22-18, 09:19 AM
Z
Received 93 Upvotes on 85 Posts
I have real acidic well water and so I was looking at a chemical (soda ash) injection system at one time. Don’t remember much about it, but I thought there was something about placing the pump-tank at the correct height in relation to the injection point.
Have no idea whether that’s true or whether it would have anything to do whatsoever with your problem – because as Marq1 points out, you would have to believe it’s the duckbill.
Just a thought.
Old 07-22-18, 09:54 AM
K
Thx. Just replaced duckbill. Let’s see.
im starting to wonder if the injection port is in the right place. It is between the holding tank and the gravity centrifuge. Centrifuge connected to carbon tank.
Old 07-22-18, 11:33 AM
Marq1's Avatar
The injector needs to be before the holding tank.
Location, height wise doesn't matter with a Stenner pump, it's under pressure so it can be anywhere!
Old 07-22-18, 02:32 PM
GregH's Avatar
Super Moderator
The injector needs to be immediately after the pump.
You should also have a flow through pneumatic tank for contact time.
If you use only only a bladder tank while the pump is running and water flowing the chlorine will bypass the tank and both not mix well and will have no contact time and will not be that effective
