water pump breaker tripping
Old 08-02-18, 07:44 PM
9
i have a submersible pump the pressure switch run between 40-60 psi the well pump is on a 20 amp breaker that keeps tripping at least 10 x a day and there is no control box the switch regulates perfect the well pump is less than a year old just put in in November 2017 can't figure out what is causing breaker to trip problem just started a week ago anyone have any ideas
Old 08-02-18, 08:14 PM
ray2047's Avatar
As a test move the pump to another 20 amp breaker.
Old 08-02-18, 09:41 PM
Received 3,999 Upvotes on 3,589 Posts
I can tell you that punctuation certainly makes posts easier to read.
What is the make and model number of the pump ?
Are you running it on 120v or 240v ?
The running amperage of the motor needs to be checked to see if it's close to nameplate rating.
