Sticky septic float
Sticky septic float
Hopefully someone here can help. My septic tank has been triggering the high level alert. I go out, turn on the pump manually and drain it. Repeat. I have narrowed my problem down to a float that when raised slowly, doesn't trip the pump on. If I bump it or manually raise it more quickly, it triggers. Does this float just need to be replaced or can I maybe shake some sense into it?
Thanks
Thanks
Okay, thanks. There are 3 floats. Should I replace them all out just the malfunctioning one? Is there only one type of plug it do I need to check it out first?
On a three float system..... the bottom one is pump off, the middle one is pump on and the top one is high water alarm. I'd just change the defective one.
I've been reading up and I think that I would need a wide angle float. I'll have to check out the plugs because all I'm seeing are piggyback plugs and I don't think I need one of those or hard wired which I don't have either. More investigation needed!😊
Thanks
Thanks
The middle float should be slightly lower than the turn on point so that as the liquid rises the float tips. Not really sure what a wide angle type would be. Most of the floats I've replaced were hardwired.
I saw wide angle meaning they needed to ride 90 degrees used for the on/off floats while the narrow angle for alarms only goes 10 degrees to trigger. It may be my wires are hardwired. Now that I think of it, the 4 wires may be going into a conduit of some sort into a junction box. I didn't look closely, they looked like round black plugs but maybe not.
