2 check valves for a sump pump
Old 09-13-18, 08:29 AM
D
Hi all-
Is there a problem if I have 2 check valves on the outlet line (pumps water outside the house) of a sump pump. I installed a battery backup pump and connected its outlet to the exiting outlet line using a split/connector. Then a second check value was installed on the main line (before it splits into 2).
The question is: Now the main pump has 2 check values in series. Does this cause any issues or add extra load to the main pump?
Thanks,
Davis
Old 09-13-18, 09:47 AM
A
Yes the second check valve will add some load to the main pump but I do not know whether that will become an issue.
You may need to add a third check valve, putting it in the backup pump line. This is so when the main pump runs the water does not go backwards into the backup pump and return to the pit. Once this is done you might as well remove the second check valve so now each pump's outlet path has just one check valve.
Old 09-13-18, 10:59 AM
Received 3,183 Likes on 2,858 Posts
Welcome to the forums.
Each pump should have it's own check valve before the lines are combined into one pipe.
Old 09-13-18, 12:27 PM
D
Thank you for both your replies. I am new to the forum and this was very helpful - this made me think of the situation where water coming out from the main pump flowing back to backup pump in the absence of a check valve for itself.
