Well casing not plumb...
I had a well drilled for my home three years ago. It was drilled with a cable rig, 5 5/8" bore, 25 feet of galvanized casing. Depth is about 90 feet, all limestone bedrock except for 25"-30" of cover soil.
I noticed the well casing is not plumb. I believe the casing to be about 1.5 degrees off vertical.
Is that amount enough to be of any concern? I'm wondering about wire/pipe abrasion, shortened pump life, etc.
You can't change it so it really doesn't matter. You are stuck with whatever angle your well is. Also, how confident are your measuring? I hope you aren't freaking out because you used your cell phone as a level.
No, a non vertical well doesn't cause problems. If you are concerned there are plastic standoffs you can put on your well pipe and wiring to keep it centered in the pipe.
ruauu2
voted this post useful.
