Chamber Lid
Old 10-17-19, 06:30 AM
Chamber Lid
I am putting a Riser on my Outlet Chamber. Right now, there is no Riser and the lid is concrete. After I install the Riser (which is about 32"), do I keep the concrete lid on or throw it out?
Old 10-17-19, 08:28 AM
Marq1's Avatar
Received 394 Votes on 368 Posts
The only risers I have installed were a very heavy PVC material and they had PVC covers.
Ive heard of concrete risers but not sure what they use, what does the manufacture/seller recommend?
Old 10-17-19, 10:40 AM
P
Received 681 Votes on 628 Posts
I've seen it done both ways. If your old concrete lid can be removed with the riser in place then I would leave it for safety. If a child or someone gets the lid of the riser off it will prevent someone from falling into the tank. Keep in mind that you will have to be able to lift the heavy concrete lid up and out through the riser when servicing the tank. My tanks only have lids on the risers as the tanks are too far underground to make removing another lid practical.
Old 10-21-19, 07:40 AM
Thanks so much! I will remove the lid underneath the Riser, since it is extremely heavy and about 2.5 feet below the Riser (which has a lid of its own). Thanks, again!
