Help with well pump replacement
Hi all! I have a old 3 season cottage which has a shallow well pump. We used a pump/pressure tank combo for 15ish years, then the pressure tank failed so we got a 20 gallon.
Now this year our pump died. I quickly figured out that the Little Green Giant Menards sold me doesn’t have the port for a pressure tank, so I’m not sure how to best get everything setup. I was thinking I could add another 3 way fitting out the top of the pump, then Connect the hose to that. Geometry seems to be against me with that thought thought. Any ideas?
This is my original setup:
https://imgur.com/gallery/c9ZvcPe
New pump:
https://imgur.com/gallery/XtXJo2e
Pump I purchased:
https://www.menards.com/main/plumbin...7334885176.htm
New pump:
Pump I purchased:
The pressure tank does not have to be mounted on the pump. You can T into the water line on the output side of the pump and install your pressure tank.
It looks to me like they used the pump draining hole for the pressure tank in the older pictures. T off of the outgoing line, as suggested, would be best. It is the more common method and it should allow for a quicker tank fill because you can use larger diameter piping.
Thank you all! So it will work ok if I leave with the tube going to the coupler without on the the $50 ‘T’ pipes they sell for pressure tanks? That’s how we always used it but want to make sure. Thanks!
https://www.homedepot.com/p/Everbilt...10NL/205618015
If you're asking if you need to use that pump tee..... no.... you don't.
You can use any tee you'd like.
Hi all,
Today I went up and got it working with the pressure tank. I’m noticing air in the lines though and there are no leaks/everything is tight. We have a 40’ 4” point with a 2” PVC insert. Any ideas?
https://photos.app.goo.gl/mia8hxUWXPuoevwE8
https://photos.app.goo.gl/VxhmV1jWK9tACKgT9
Air can get into the lines whenever you are installing new components. If that's how it got in then the air will work itself out over time. If you continue to get air in the line then you may have a leak, likely on the suction side of the pump.
Thanks! I’m going to go through everything today. I got it up and running on Thursday and it was fine until I tried to fill my hot water heater, then it lost prime. It looks like shallow well pumps are only good for 25’ of water. If my point is 40’ with probably 30’ of water does this pump fit my application?
The alternative is that the screen on the bottom of the point is clogged and it’s not filling up quick enough. I read that you can put muriatic acid in to eat through mineral deposits. I’m trying to find where I can get that.
I'm not a well pro so I can't offer any help with using acid but....
Muriatic acid is widely available. Lowes, Depot, Amazon, Ace.
You need to check the acidic level. Most are around 15%. You may need something stronger.
A standard single pipe well is only good for around 25' deep.
If you have room in the casing you could add a shallow well jet kit and a second line.
Losing the prime sound like the water level is below the pickup pipe.
It is possible you are pumping the well dry. A well that small has almost no storage capacity so you are limited by how quickly water can flow into your well point.
