Pipe leaking next to well pump housing
Hey guys, I'm looking for some insight.. I'm wondering what this pipe running parallel to my well pump housing is?
I never noticed it before but the cap is leaking. I haven't had a chance to dig deeper but from what I felt, it threads into a piece of PVC that joins to (maybe poly pipe? As it bends fairly easily) that butts up next to the well pump housing and continues down.
What I'm wondering is A. What is the pipe/what's it tied to? And B. Is it likely that this leak is the issue I just noticed with low pressure in my system?
Back story - I just dewinterized my irrigation and noticed low pressure in virtually all zones. I went in the basement to check my pressure and I noticed it was sitting at 38psi and not cycling on/off as it should (my switch is 40/60). I let a sprinkler zone run and I turned on a sink and saw my pressure drop to about 20psi. I turned everything off and still heard/saw no movement on my switch but I was building pressure back up, just slowly to about 40psi then very slowly beyond that (never got to get back to it as company was over so I'm not sure what it built up to). Only other note worthy thing was the well pump line was humming (as if it was running or struggling to run) after everything has been closed.
Any advice would be greatly appreciated. Thanks in advance!
EDIT: Maybe it's worth noting - It's possible it may have gotten air bound or an air pocket when I pressurized the irrigation? My backflow preventer did leak a little at first and the line shook a little as I was running through the zones but it cleared itself out and nothing leaks now nor does anything shake.. but I don't see how that would cause this leak or have an effect on the pump. If it's airbound tho, I'm wondering if I can vent it at the gate valve that's like right next to the pressure tank. I should just be able to crack that to bleed the air. The other odd thing is the switch wasn't even cycling like it should of been when I was running the water as I stated prior to this edit.
File size:120.3 KBViews:8IMG_20200526_084532.jpg
File size:156.4 KB
Received 93 Upvotes
hi mark –
Not one of the experts here, so probably I’m not much help. But the small white pipe next to the larger one in the bottom pic, I think carries the electrical wires for the pump. The thing which looks like a brown handle in the other pic I think might be a vacuum breaker. If the vacuum breaker is broken and doesn’t seal under pressure, I think that could cause a pressure problem and I think you might also see water coming out from the vacuum breaker.
But not really sure of all that. Hope one of the experts jumps in!
Welcome to the forums.
If the pump was running the switch would not be cycling..... it would be on.
It sounds to me like you have a water supply/refresh problem or a worn out pump.
Does this pump supply the house and the irrigation ?
Do you know the well depth ?
