Basement ejector pump
Received 0 Votes
Can you drain a washing machine into a basement eject
or pump? Will the suds interfere?
It depends on what your ejectment pit is. If it is sewage then yes you can use it. If it is a sump pump for ground water then no you can not discharge your washing machine into it.
This thread is basically the same as you are asking..... sump-pump--for-basement-washing-machine.
