Sump Pump
Old 12-18-20, 08:33 AM
P
Sump Pump
I have a " Little Giant " Sump Pump installed a couple of years ago and it`s was working fine up to a month ago. It started making a loud suction noise at the end of it`s cycle. It still works and is operated by a pressure switch. Just wondering if maybe there is a problem with the switch. Maybe it`s not working right. Any advice?
Old 12-18-20, 01:25 PM
P
Received 1,776 Upvotes on 1,588 Posts
It sounds like the switch is allowing the pump to run a bit too long. Adjust the switch or it's location so the pump turns off just before it sucks air.
Old 12-19-20, 09:49 AM
P
Thanks for the advice I will try that
