Sump pit? What to do
Old 04-15-21, 05:06 PM
In a room of the finished basement I could feel that the floor was not solid. I pulled up the flooring and discovered this. There was maybe, an inch or so of standing water, pebbles and a leaf.
I think it may be a sump pit, but there is no sump pump. I have had no issue with flooding in the daylight basement in the 4 years it has been occupied.
I have an appointment with a waterproofing company in the coming weeks, but I was hoping someone here could give me some in sight to what I may be dealing with here?
Old 04-16-21, 05:26 AM
P
Received 1,776 Upvotes on 1,588 Posts
It looks like part of the foundation drain system. Look at it after some heavy rain. You might see water coming out of two of the pipes and draining away via the third. I don't like that you mentioned finding a leaf. That means they could be from the downspouts which could be dangerous if the drain pipe ever clogs.
Old 04-16-21, 06:00 AM
Received 35 Upvotes on 33 Posts
It could also be the location of a sump pump that was used when the basement was unfinished. The previous owner may have converted to a different sump system when he finished the basement.
Look above the pit and see if you can find the exit point for the previous plumbing.
Do you know if you have a sump pump now?
Old 04-16-21, 02:17 PM
A
Received 251 Upvotes on 231 Posts
Connect up a garden hose to a faucet and stick the end up one of those corrugated pipes at least five feet if possible. Turn on the water. If all the water comes right back out into the pit then you probably have a regular perimeter drain pipe dumping into the pit. Try the next corrugated pipe, etc.
Another thing you could do is have someone do a video examination of each pipe. If the pipe shows perforations all along its length and comes to a sudden 90 degree bend that the camera snake won't go around, that would suggest that the pipe is a perimeter drain pipe.
Pull off the off white cover over the fourth opening dumping into the pit. Try the garden hose up that opening also.
If at least one of those pipes carries unlimited water away from that pit then you don't need a sump pump. Still, the pit should remain accessible, like, not covered over with wall to wall carpeting.
Old 04-17-21, 09:22 AM
Thanks for the responses everyone.
The basement is a day light basement and this is in the corner of a finished room on the "daylight" side. There is no pump system in the basement. There is drain in the other corner of the basement in the utility room. No signs of flooding ever.
I am sure I could construct a cover for opening or shelf covering, but I am still concerned with moisture, mold etc.
Old 04-17-21, 09:27 AM
And all down spouts seem to flow to the ground from the roof.
Old 04-17-21, 11:49 AM
H
Received 277 Upvotes on 237 Posts
My guess is that the builder poured a sump pit/foundation drain, found they didn't need it.
Could also be a roughed-in under slab radon system (depending on where you're located).
In my area (SE Pennsylvania) it's becoming more common for these to be roughed in when the basement is poured: if you need it, it's there: if you don't need it, you don't worry about it.
Old 04-17-21, 11:58 AM
I do have a radon system in the other section of the basement in the other end of the basement int the utility room. Just seems odd there is a small amount of water and no flooding in the years it has been occupied
