Trash pump
Old 09-19-21, 07:47 AM
G
Trash pump
I have a diesel fueled Trash pump. I normally store in our basement. My question is would it be ok to store it outside in a storage shed. It's getting harder to move outside when needed, because of steps. I would appreciate any comments.
Old 09-19-21, 08:45 AM
Norm201's Avatar
Received 663 Upvotes on 586 Posts
I don't see any reason why not. You might want to spray the outside with a silicone spray just to keep surface rust off, but I don't think it would make any difference one way or the other.
Old 09-19-21, 11:03 AM
Received 3,415 Upvotes on 3,063 Posts
Maybe add a fuel stabilizer to counteract temperature changes and moisture in the fuel.
Old 09-19-21, 11:57 AM
Norm201's Avatar
Didn't think if it was gas or electric. If gas make sure the carb is dry and clean. Only add fuel when in need and then be sure let it run out when done. You might want to buy the non-ethanol fuel. It will hold up a long time.
Old 09-19-21, 03:09 PM
Didn't think if it was gas or electric........
It's neither.... it's diesel.
Old 09-19-21, 03:31 PM
Norm201's Avatar
I looked right past that.
Old 09-20-21, 06:27 AM
G
Great advice everyone, do you all think it would harm the gaskets or seals?
Old 09-20-21, 09:27 AM
P
Received 1,759 Upvotes on 1,572 Posts
Consider that many cars and most diesel powered construction equipment live outside and are never stored inside. Certainly inside is better for theft protection and cutting down on rust but lots of construction equipment and tools ends up living out of doors.
Old 09-22-21, 07:26 AM
G
Thank you very much everyone.
