How long before pvc joint can be used after being glued
Old 10-17-21, 03:15 PM
Q
Received 1 Upvote on 1 Post
Hello all,
I need to repipe my sump pump pvc connection pipes and I plan to use "8 oz. Purple CPVC and PVC Primer and Regular Clear PVC Cement Combo Pack".
How long do I have to wait until I can put the pipes back into services?
Some joints will be submerged into water with the sump pump while others will have thread connection to check-valve.
Thank you
Old 10-17-21, 04:56 PM
Norm201's Avatar
Received 672 Upvotes on 595 Posts
Almost immediately. Wait about an hour to be sure it sets.
q0987 voted this post useful.
Old 10-17-21, 08:10 PM
Received 3,422 Upvotes on 3,068 Posts
If the glue is new and fresh...... it will set to use almost immediately.
If it's old..... it will work but stay gummy and take hours to fully dry.
Old 10-18-21, 12:19 AM
Marq1's Avatar
Received 1,104 Upvotes on 1,004 Posts
If it's a non pressure type fitting like a drain pipe, your good to go after it dries, maybe a minute. Pressure joints, I give it 30 min.
Old 10-18-21, 02:12 AM
Received 741 Upvotes on 647 Posts
Doesn't it say on the label to let it cure for 2hrs before pressurizing ??
Old 10-18-21, 04:37 AM
P
Received 1,766 Upvotes on 1,579 Posts
I try to wait a few hours though for drain lines where there is no pressure I have never had a problem when allowing water to flow right after gluing the joint. I have had some luck prying fittings apart after 10 minutes which confirms that the glue does need time to dry so if using PVC for a pneumatic system that might be at 120 psi I would wait overnight.
Old 10-18-21, 05:52 AM
Marq1's Avatar
Ever see a video of a PVC pipe exploding?
Old 10-18-21, 06:17 AM
Norm201's Avatar
No. You have a video available?
Old 10-18-21, 01:09 PM
