Bubbling from 2nd check valve on backup pump
Old 10-24-21, 10:53 PM
T
I have 2 sump pumps, both the same, zoeller m53, both go thru quiet check valves , then the pipes come together to one output. The main sump sits on the bottom of the hole, the second is completely above the water line when it's at its highest b4 the main pump kicks on to move the water. After the main runs and drains the crock, the check valve on the secondary pump bubbles, gurgling to be honest. No water passes back thru the 2nd check valve as observed b4 I attached the 2nd pump. 2 questions
1) would a 3rd check valve just above the union fix or lessen the bubbling?
2) any suggestions on how to stop the bubbling without a 3rd check valve?
Pictures of my set up
Old 10-25-21, 01:02 AM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums.
It's bubbling from the venturi effect.
As the main pump is running it's drawing water or air thru the second check valve.
The bubbling shouldn't affect the pump's operation.
Three check valves won't change anything.
Old 10-25-21, 08:43 AM
T
Thank you
Thank you for the quick response. Is there anyway to stop the bubbling from happening?
