Underground well plumbing
Old 11-08-21, 03:57 PM
C
Hey All, I have installed a 1 inch poly line for my main water supply from the well to the pressure tank. Between the two, I have installed a "T" to supply water to my 5th wheel while I build. Well, the spigot at the end of the T spews water when opened for a few seconds but then diminishes until nothing emerges. Once closed for awhile, same thing happens. Is there some one-way valve or other device missing? Can't figure this one out, thanks.
Old 11-08-21, 09:21 PM
Received 3,424 Upvotes on 3,070 Posts
Welcome to the forums.
It sounds like you may have a check valve at your pressure tank area. That would maintain the pressure in the tank and keep the pressure switch from turning on.
You're taking water before the check valve and your pressure switch is on the other side.
Old 11-08-21, 10:16 PM
C
AMEN! You are 100% correct, thank you for that answer, it makes perfect sense.
