Add camper blackwater drain line to existing cess pool
I’m looking for info on how to add a blackwater drain line from my camper into my homes existing cess pool.
I’m not sure where the best (and safest) entry point would be (top-side or side-entry) and what to expect when I create the entry point.
presently there is no entry into the cess pool for any type of maintenance.
I’ve had no problems with the cess pool to this point.
Easiest would be to tie into the main drain line coming from the house. This could also be used as a cleanout location if you have a clog in the future.
You would be using the connection on a temporary basis to drain the camper tank.... correct ?
A permanent connection would be more difficult to a camper and just leaving a flexible hose stuck in a hole in the ground would be a problem.
