Sump pipe dripping water
My sump pipe outside is dripping water. Not sure why. Sump pump isn't running. In do have the water treatment system running into the same outlet pipe. Bit that runs once a day. And the AC does drip into well but don't always run the AC. And it still drips outside. It's really a constant slow trickle. Thanks.
Welcome to the forums.
You have two items draining thru the same drain pipe..... the sump and water treatment system.
If the sump pump isn't running.... that leaves the treatment system.
If it's the type that flushes with fresh water.... then the valve may be leaking.
