Draining a tank for mechanical sewer
Old 07-10-22, 05:09 AM
Received 2 Upvotes on 1 Post
I purchased my parents house. We have a mechanical sewer system that drains into the ditch. Whenever I open the cover and look into the tank I see water. Someone told me that I'm supposed to empty this tank every few years is that correct? I have no one to ask about this and I fear that the answer is probably going to be yes. If that's the case then why is there a pipe draining to the ditch?
Old 07-10-22, 08:10 AM
P
Received 1,768 Upvotes on 1,581 Posts
What is a "mechanical sewer system"?
Old 07-10-22, 10:50 AM
That's what I have called it for the last 30 years of my life. It's a hoot system.
Old 07-10-22, 11:25 AM
badeyeben's Avatar
Received 54 Upvotes on 48 Posts
Here is a PDF on the Hoot system. The bottom of page 7 and top of page 8 explain the pump out reasons and procedure. http://septic.umn.edu/sites/septic.u...ers_manual.pdf
Old 07-10-22, 03:40 PM
I guess that means yes I need to get it pumped.
Old 07-11-22, 05:02 AM
P
Maintenance of Engineered systems like yours is very important. Do not cut corners. If it fails it can be very expensive to repair or replace.
