Deep well jet assembly question
Received my new jet package this morning without instructions. This jet assembly will be hung 44' down a bored well, six feet off the bottom and uses an AO Smith 1/2 hp motor with 1' and 1 1/4 piping.
The jet has 5 different venturi pipes (maybe called nozzles), two are 4" long and 3 are 5" long. I called the supplier and was told to use the 4 inch with larger bore. Perhaps that is correct-my previous assembly used the longer 5" venturi/nozzle.
Can anyone confirm the 4" large bore is the correct one to use?
I found an online video of the assembly of the jet package. That supplier only supplied one short and one long venturi. They used the long one for an application over 25'.
