Foam Carving
Old 06-19-07, 07:47 PM
Foam Carving
I am trying to find some high density foam that is not too expensive that i can cut, shape and sand. I dont need to do much work to it. I am using the foam to re-inforce a plug i am using to make a mold for. I want to use the foam to fill some space and to create some shape before the horizontal flange starts.
Old 06-19-07, 08:10 PM
Are you talking about styrofoam? Check at local craft stores. You will find styrofoam and florist foam.
Old 06-20-07, 05:04 AM
mattison's Avatar
What type of foam are you looking for ?? The expanding insulation foam could be sprayed on like wax paper into a big blob and it cuts and sands great.
Old 06-20-07, 02:06 PM
Shadeladie's Avatar
Super Moderator
If you're talking about the HD foam used in cushions, try an upholstery shop or a marine supply place, but foam has really gotten very expensive and the more dense and firm it is, the more it's going to cost. I don't think you can find it that cheap.
