Bending silverware (and not with my mind!)
Does anyone have any tips for bending silverware? I found some very cool ideas for silverware crafts online but the only luck I am having is bending the spot right at the base of the spoon/fork....and I really want to bend the handle part.
I tried to heat them in boiling water first, and that didn't help. So I tried to heat them in a 500 degree oven, and that didn't help either.
The only tips I can find are those which involve total concentration and a bit of psychokinesis. Now, I tried, really tried, to hold that fork and think very hard "I can bend you with my mind".....and it didn't work (at all, can you believe that?)
Thanks, guys!
Thanks, guys!
I agree with mitch17. Look around for propane torches.
When you use it, make sure you use it on a heat-resistant surface and wear eye protection and gloves.
The psychokinesis thing really works, it really does! I think you weren't concentrating enough. Try it again. If all else fails, try the propane torch ha! j/k
Psychokinesis? Hate to dishearten you. http://www.wikihow.com/Bend-a-Spoon
A metal vise and needlenose pliers can be used to bend silverware. Some find that bending around a rolling pin or large dowel works.
To bend with propane torch: http://www.diynetwork.com/diy/cr_met...256213,00.html
