Can one thin Gorilla Glue?
Old 03-15-09, 07:20 AM
I use Nano Glue or Gorilla Glue for my models and projects. Somethimes I get to my relatively ful bottle and find that it has thickened up from non-use. I either need stronger glasses or it doesn't say on the label but, is there a way to thin it out to become more user friendly?
Old 03-15-09, 07:24 AM
the_tow_guy's Avatar
Not that I know of. You certainly can't use water because water's a catalyst for the poly glue.
Old 03-15-09, 07:30 AM
Gunguy45's Avatar
Super Moderator
Agree..never saw anything for that..
Heres some hints that I'm pretty sure apply to that glue though.
Store it upside down, then the stuff at the bottom will harden or thicken, since thats the part exposed to the air in the bottle. Make sure the cap is on tight!
Also, I think you can store it in the fridge...just remember to take it out before you need it.
Poly glues do have a limited shelf life once opened...buy smaller bottles if you aren't going to need it often.
Old 03-15-09, 07:43 AM
You're supposed to squeeze all of the air out of the bottle and then put the cap on in order to extend the shelf life after opening. I tend to buy glue in the smallest size just because it does have a limited storage life. I also write the date I opened the bottle on it somewhere with a marker and throw it out after a year.
Old 11-04-12, 11:39 AM
I have read that either acetone, denatured alcohol or less than 5% water [Gorilla themselves] can be used to thin it, but it was either stated or only implied, it was for use, not storage [water obviously will cure it]. Any one heres otherwise it apparently is still an unknown???
Too keep air out of the bottle easier, without squeezing it, also with other various finishes like Tung oil [it's expensive], just add marbles until it reaches the top. Less waste, but you still can't use it all.
Trackbacks are On
Pingbacks are On
Refbacks are On
