Removing rust from stainless steel boat sink
Old 06-01-10, 02:57 PM
In my boat the sink has some rust spots from over the winter storage. I'm not sure, but I'm thinking removing it by sanding it, and more importantly use high grit in the end to maintain the satin finish. Am I thinking along the right lines?
Old 06-01-10, 04:02 PM
Speedwrench's Avatar
use a stainless polish and then some type of seal coat
murphy was an optimist
Old 06-02-10, 06:02 AM
Whatever you use on your sink use new. New sandpaper, Scotch brite pad or a clean rag with stainless steel polish. Particles of steel caught in the grit of old sandpaper can get embedded in the stainless and rust. Also avoid using anything chlorine on stainless steel. Chlorine can cause stainless steel to rust by eating away the thin passivation layer that protects the metal from rusting.
Old 06-02-10, 12:55 PM
Okay thanks for the reply. I will give it a shot and will stay away from chlorine based products.
