Veneer Application
Old 11-16-17, 06:07 PM
W
Veneer Application
Should I apply a coat of shellac to the glue side of a piece of veneer before gluing it to the substrate so as to prevent glue bleed through?
Old 11-17-17, 05:06 AM
Norm201's Avatar
Received 255 Votes on 229 Posts
It's been many many years since I did this, but I did not apply anything to the base substrate 1st. It seemed to work well.
Old 11-17-17, 05:54 AM
P
Received 684 Votes on 631 Posts
I have always used contact adhesive when doing veneers and there was no bleed through.
Old 11-20-17, 08:31 AM
Received 94 Votes on 83 Posts
I would be concerned about the shellac keeping the glue from holding.
As Dane, I use contact cement.
Old 11-21-17, 07:43 AM
G
Received 1 Vote on 1 Post
What kind of veneer & what kind of glue? Traditional sawn veneer is thick enough to prevent bleed-through of water-based white & yellow glues.
Contact cement is popular with the thinner veneers but might not be strong enough to flatten ripply natural veneer unless you use many clamping cauls or a vacuum bag press.
Also many thin veneers have a backing that lessens problems with cracking, glue bleed, or finish bleed attacking the glue.
Shellac is a good barrier to prevent all these problems.
