10 Advantages of Wall Radiant Heating 10 Advantages of Wall Radiant Heating
Wall radiant heat uses the principle of heat radiation to spread warmth to people and objects in the vicinity. Wall radiant heat systems may use air tubes, water pipes or electric cables to transfer heat. These systems have several advantages over conventional forced air heating systems and furnaces.
1 – High Efficiency
Wall radiant heat systems are much more efficient than conventional forced air heating systems. The increase in efficiency is largely due to the basic principle of radiant heating. It works by transferring heat to nearby objects and people, not the surrounding air. As a result, optimum temperature levels are achieved by spending much less energy.
2 – Lesser Losses
A traditional heating system works by heating air and then sending it throughout a building via ducts. The problem with this type of heating system is that a lot of heat is lost during the transition phase. Also, cracks or dents can increase the amount of this loss. In contrast, a wall radiant heat system conserves a majority of the heat emanated.
3 – Fast Response
Because there is minimal energy wastage and no time wasted on heating up the surrounding air, a wall radiant heat system is much faster to respond to the thermostat setting. You can feel warm in a matter of minutes.
4 – High Comfort Levels
Wall radiant heat systems actually make feel people warmer at lower temperatures. This is due to the principle of radiation and the reduced heat losses. As a result, higher comfort levels can be achieved with one of these systems.
5 – Rooms Can Be Maintained at Different Temperatures
Most wall radiant heat systems can be separated into individual zones, all of which can be maintained at different temperatures. This can help in reducing your heating costs considerably, especially when people are not home or there is only one person occupying the home for a few days.
6 – Saves Energy
Wall radiant heat systems conserve energy in a variety of ways. First is the minimal loss of heat because the heat is passes on to objects and not the air. Reduced air movement also contributes to greater efficiency and lower energy costs. In addition, the ability to maintain different temperatures in different areas adds to the overall appeal.
7 – No Combustion By-Products
Unlike wood or gas burning stoves, fireplaces or furnaces, a wall radiant heat system is totally clean and concealed. There are no toxic emissions to worry about.
8 – Reduces Occurrence of Allergies
A common complaint with forced air heating systems is that the air moving around aids the spread of allergens. This issue is effectively tackled with the use of wall radiant heat systems.
9 – Compatible with Many Energy Sources
You can use gas, solar power, electricity, wood or oil to heat up the air or water in a wall radiant heat system. This greatly enhances the flexibility of these systems.
10 – Reduces Chances of Dry Skin
With an enclosed wall radiant heating system, the occurrence of dry skin is greatly reduced. The incidence of dry throats and nasal passages is also greatly reduced, which helps in the reduction of sickness.
