10 Utility Knife Cutting Tips
A utility knife is a handy tool that is useful in many different situations and tasks. This type of knife is retractable and can be encased in a cover when not in use. This makes the utility knife easy to carry as well. Utility knives are suitable for tasks such as opening boxes or cutting through foam board, ropes and other soft materials. For effective and safe use of a utility knife, you can follow some of the cutting tips enlisted below.
1 – Choose the Correct Type of Utility Knife
Utility knives are available in different sizes and levels of sharpness. Choose the tool that is best suited for your needs. For example, you must use different utility knives to cut a rope versus a cardboard box. Use knives with secure handles that let you work properly.
2 – Prepare the Work Surface Beforehand
Before commencing work, protect your work surface with rag cloths, papers or scrap wood. This will prevent scratch marks on the surface.
3 – Keep the Object on a Flat, Stable Surface
Never cut objects that are placed on unstable or unsteady surfaces. This can cause accidents and unsatisfactory results as well. Also ensure that you have a steady footing as you work.
4 – Stand up as You Start Cutting
Avoid sitting or stooping when you use a utility knife. Stand up on a steady surface and position the object carefully.
5 – Hold the Utility Knife Properly
To hold the utility knife properly, keep your index finger on top of the protruding blade while holding the handing in the palm of your hand. Keep a steady grip on the knife as you work.
6 – Keep Your Fingers and Body away from the Cutting Line
As you work, keep your fingers and body away from the cutting line. Also ensure that young children or other people are a safe distance away. Always cut away from yourself and other people in the vicinity. If you are holding the object with your other hand, be particularly careful and wear gloves if needed.
7 – Pay Close Attention to the Task at Hand
Avoid looking elsewhere or talking to people as you cut with the utility knife. This may result in accidents and your job will not be done properly.
8 – Adjust the Blade as Required
Most utility knives have blades that can be retracted and expanded as per requirement. Adjust the length of the blade as you need. Make sure you lock the blade in place before you start cutting.
9 – Avoid Using Excessive Force
When you are cutting an object with a utility knife, avoid using too much force. Run the knife over the object a couple of times, if needed to achieve a smooth cut. Avoid going back and forth with the blade. Use smooth strokes along the length of the material.
10 – Always Retract the Blade after Use
After you finish using your utility knife, retract the blade inside. If you forget to cover the blade, you may accidentally keep it in your pocket or someone else may lift it carelessly.
