11 High Tech Tools to Get on Prime Day 2021
solar power station charger
  • 1 hours
  • 8-400
Amazon offers the ultimate convenience and selection when shopping for things you may or may not need. During Amazon Prime Days, some significant price drops on techy equipment for the home and shop make it all that much more tempting to upgrade or consider a new purchase.
Note: To get the lower prices, you have to be an Amazon Prime member, so you might want to sign up for a 30 Day Free Trial here. Also, note Amazon prices change frequently, so click through to see the current pricing.
1. ROCKPALS Portable Power Station
Charge all your phones, tablets, computers, GPSs, and photography gear with this portable power solution. With six ways to charge it, you’ll have options, whether relying on a home outlet, solar panel, or auto port. Weighing ten pounds and measuring less than one foot across makes it a lightweight and convenient solution when the power goes out or for your next outdoor adventure.
2. KAIWEETS Rotary Laser Level
When it comes to precision, a level is the DIYers best friend. This multi-surface level is the ultimate convenience tool, with laser lights that hit all surfaces in the room simultaneously. That means even when hanging art or construction beams across the room from each other, they will come out level. Plus, it’s self-leveling, comes with two batteries for uninterrupted work, and can be used indoors or outdoors.
3. Beanie Hat with Built-in LED Light
black beanie hat with light
This lands in the category of things you didn’t know you needed. But now, you no longer have to choose between wearing a hat for warmth or a headlamp for necessity. This convenient two-in-one tool/headgear comes in 10 color options, costs less than $10, and of course, has free shipping and returns if you fail to ‘see’ the benefits once it arrives.
4. Electronic Stud Finder
If you’ve ever tried and failed to perfect the wall-tap technique to identify where studs are located, you’ll be able to appreciate the simplicity and necessity of an electronic stud finder. Turn it on and move it across the wall until it indicates a stud location. No more missed studs.
5. BoYing Waterproof Wireless Door Bell
wireless dorbell with white and blue design
Skip the electrician’s 101 class and still have a doorbell installed in record time. It’s especially convenient for areas where you normally might not hear the doorbell ring, and it’s as easy as mounting the doorbell button to the surface and plugging the receivers into an outlet indoors. Ding dong done.
6. LED Flashlights Gloves
gloves with finger lights
Wait, flashlights built into gloves? Where have these been? Great for biking, making vehicle repairs, fishing, camping, backpacking, or walking the dogs after dark.
7. KINAVEL 4x360° Laser Level
It’s another laser level because they are just that cool. This one offers two horizontal and two vertical lasers for just about any DIY task you’re working on. Install tile shower walls, laminate flooring, doors, paving stones, curtain rods, wall decor, or creative paint designs with ease. Be sure to check the box to save an additional 10%.
8. Fluorescent Grow Light Fixture
If you’ve ever considered starting an indoor garden, these grow lights will get you off to the right start. They come in a variety of sizes to suit any need, and there is no hardwiring required. Simply plug them into existing outlets.
9. LED Work Light
led work light panel
Every home and vehicle tool kit should include a few work lights. They shine success on car and home improvement repairs with little effort or expense. It can make a world of difference when you get a flat tire or need to set up a tent after dark. This one offers three settings and is waterproof (in case the above scenarios happen in the rain).
10. YOMYM Water Bottle Dispenser
You have a big water jug, but it’s challenging to maneuver, or you don’t want to buy an expensive water cooling machine or pay for monthly service. This water pump solves the water movement issue for less than $10. Simply insert the BPA, food-safe hose into the bottom of any size jug with a standard 2.16-inch neck. You don’t even have to remove the lid. The pump is battery-powered, so you don’t have to plug it in, and it’s rechargeable with the use of a USB cord.
11. Solar String Outdoor Lights
solar lights with remote
Each strand of solar-powered fairy lights is 66-feet long. Simply hang, mount the small solar panel and connect the two for a season of twinkling nighttime illumination. Each set is easily controlled by a remote, and you can swap between eight modes. Already marked down a few bucks, click the box for an additional 50% savings.
