15 Things to Do with Apple Cider Vinegar
With so many different uses and benefits, apple cider vinegar is quickly becoming a staple for any home. Not only does it have great flavor, but apple cider vinegar also boasts a number of health advantages including skin therapy, hair benefits, and even weight loss opportunities. With that in mind, here are 15 things you can do with apple cider vinegar.
1. Teeth Cleaner
Do you have stubborn teeth stains that won’t come out? Apply apple cider vinegar directly to teeth and rinse with water to remove troublesome stains. In addition to removing stains on your teeth, a solution of apple cider vinegar can also help deal with bad breath.
2. Massage Treatment
If you're looking for a way to get the benefits of a massage without having to go to a masseuse, consider applying apple cider vinegar to your hands and feet. The liquid has certain properties that bring relief to the body, including aching feet and hands.
3. Hair Product
Applying some apple cider vinegar to your hair is a great way to make it shine. Simply pour 1/2 tablespoon of it per cup of water into an old shampoo bottle and apply after shampooing.
4. Foot Odor
Apple cider vinegar can also be used to prevent foot odor. The acid inside the vinegar helps to prevent and kill the type of bacteria that create odors.
5. Dishwasher Cleaner
As an alternative to the typical dishwasher cleaners that use harmful chemicals to clean the appliance, apple cider vinegar gets the job done while leaving the dishwasher smelling better than ever. Simply run a cup of the vinegar through one cycle to clean out even the worst build-ups.
6. Decrease Heartburn
If heartburn is a consistent problem, apple cider vinegar can be used to alleviate such symptoms. Following a meal, drink a teaspoon of apple cider vinegar with a glass of cold water for best results.
7. Fabric Softener
For those who are sensitive to the harsh chemicals used in many fabric softeners on the market today, apple cider vinegar offers a healthy alternative. Simply pop in half a cup of vinegar per load and your clothes will be conditioned in no time.
8. Mood Enhancer
When consumed prior to meals, apple cider vinegar can actually enhance moods by promoting amino acids. These types of acids are important in releasing chemicals that make the body feel good.
9. Air Freshener
Apple cider vinegar is a great way to add an apple fragrance to any room. For bathrooms, simply add a little apple cider vinegar to the toilet and let it stay overnight for a fresh apple smell in the morning. For other areas of the home, a solution of apple cider vinegar and water can be used on surfaces to freshen the space.
10. Sunburn Treatment
Apple cider vinegar is a great way to reduce the ill effects of a sunburn. The perfect solution is a mixture of about 25 percent vinegar with 75 percent water, which should be applied to the skin via a washcloth.
11. Window Cleaner
If dirty windows are an issue in your home, then try applying a 50/50 mixture of apple cider vinegar. After spraying the windows thoroughly, allow the solution to dry before wiping clean.
12. Wart Remover
Apple cider vinegar is a clean and easy way to remove warts. Apply the substance directly to the wart via a cotton ball, and continue the process for as many nights as it requires to remove the wart.
13. Deodorant
For those looking for a healthier alternative to commercial deodorants, apple cider vinegar can be just as effective at eliminating smells. Apple cider vinegar works as a natural deodorizer and can be used to ward off armpit odors.
14. Sleep Aid
Having trouble sleeping? In one of its many uses, apple cider vinegar is a great way to get a restful night’s sleep. To do so, mix 1 tablespoon of vinegar with a splash of honey and some warm water and drink.
15. Weight Loss
In conjunction with water, apple cider vinegar can be added to a diet to promote weight loss. In fact, one of the main ingredients of this solution is acetic acid, which has been shown to help with weight loss. Simply mix 2 teaspoons of apple cider vinegar to approximately 16 ounces of water and drink several times a day.
