2 Common Causes of Slow Flowing Iron Pipes 2 Common Causes of Slow Flowing Iron Pipes
Slow flows can affect all kinds of pipes, including iron pipes. When this happens, you might find that water takes a long time to get to the faucet, or takes a long time to drain away. These kinds of problems are more common among older plumbing systems, so the best long-term solution is to replace your aging pipes. However, in the short term, you can perform a quick fix on slow flowing iron pipes once you know what the problem is.
1. Frozen Pipes
This is the most common reason for water to flow more slowly than usual. Frost on the ground can affect iron pipes very seriously, and may even cause them to crack. In order to ensure that the pipe is not damaged, you need to warm up the pipe slowly by wrapping it with cloths and towels. Don't heat the pipe directly, as the contrasting temperatures can shatter the metal.
2. Blocked Pipes
For drainage systems, a slow flow might indicate that your iron pipes have become blocked with dirt and grease. This can significantly reduce the amount of water which passes through the pipes, and may even block it completely. You can solve this problem by moving the water with a plunger, and then using a drain fluid to reduce the blockage.
