2 Common Screen Door Installation Mistakes 2 Common Screen Door Installation Mistakes
Screen door installation is an easy enough task to undertake, but there are two common mistakes made when the installation is underway. Make sure you carefully read installation instructions to avoid these mistakes as they are not easily repaired and will make your installation unattractive.
Vertical Mounting Frames
The first common screen door installation mistake is made when cutting the vertical mounting frames. Often times, these are cut too short, and they need to properly fit inside the openings.
Cutting Holes for Hardware
These cuts must be precise on your screen door installation. If you drill and cut the holes without using the template provided, or in the wrong location, then you will end up with an unappealing and ugly set of holes in your screen door. Take your time and follow instructions carefully and you will be able to complete the screen door installation without a hitch.
