2 Different Types of Tree Loppers
There are a number of different types of tree loppers available to the keen gardener. Tree loppers are used to cut the very top branches off of trees, and so you will need to consider the different types of trees which are currently in your home in order to ensure that you get the best kind of tree loppers available for your needs. Many gardeners buy the first type of tree lopper which comes into their hands, but this is not the best way to go if you want to get a professional look for your pruned trees. The tree lopper is divided into two main types of tree lopper, the bypass and the anvil type. These are then divided into smaller different styles, depending upon the size and shape of the handles and blades. In all types of lopper, you can find handles which extend the range of the chopper, although this may inhibit the leverage.
1. Bypass Loppers
These are the type of loppers which are familiar to most amateur gardeners. If you have a pair of shears in your garden, then you have the basic style of a bypass lopper. These work by having two poles with handles at one end and a blade at the other. The handles are attached in an X shape, so that each handle moves one of the blades. A two-handled style of tree lopper, the bypass loppers blades are placed on either side of the branch that you wish to cut, and then the handles are moved apart. The blades then cut off the branch. You should always be careful when you are using bypass tree loppers, as the branch can be cut through and drop onto the body of the user. Bypass loppers are considered to provide a better cut than other styles. Bypass loppers can also be tightened at the fulcrum, which can also be useful in getting rid of trapped parts in the blades.
2. Anvil Loppers
The other major form of the tree lopper is known as the anvil lopper. Like the bypass, these are usually made of two large poles which have a handle at one end. Unlike the bypass, however, the anvil only has one cutting edge. It functions much like an anvil in that it hammers the branch apart, rather than cutting it loose like the bypass. The cutting edge presses the branch against the blunt edge, so that the tree may be bruised and damaged by the cutting action of the anvil cutter. The anvil cutter can be adjusted by using a screw which is attached to the fulcrum, but you can also remove the flattened blade, which may become worn down or damaged through constant cutting. Anvil cutters are not usually appreciated, as they can cause very serious injuries to the tree, and bypass cutters are considered to be more efficient, as the anvil cutter does not have quite the same accuracy of cutting.
