2 Popular Salt Water Pool Systems
Popular salt water pool systems are being patronized by people because swimming in water that has a mild salinity is just like taking a soft water shower. A pool that contains no salt water makes the skin dry quickly upon getting out of the pool. There can also be chlorine flaking on the skin which are seen as whitish residues. A salt water pool will make you feel better refreshed, and the water and your skin will feel smoother.
Systems for Small Salt Water Pools
If you have a pool that contains around 15,000 gallons of water, you can use a system that uses high performance electrolyte cells that are durable and made from titanium plates. It has reversing cycles that run automatically and is self cleaning. Such systems can be used in 115 or 230 voltage and carries a prorated 5 year limited warranty.
Salt Water Systems for Larger Pools
If your pool has more than 15,000 gallons of water, you can use salt water systems that were designed for use on pools that hold up to 40,000 gallons of water. Such systems use common salt that they convert into free chlorine. This will prevent swimmers in your pool from worrying about dry and itchy skin, green hair, bleached bathing shits and red irritated eyes.
